ᐅ Lighting for Semi-Detached Houses – DALI & DMX or REG-LED Controller?
Created on: 27 Jan 2018 21:07
Matt Yao
We are building a semi-detached house in Lower Bavaria this year. Currently, we are working on the lighting design, which we want to implement partly with KNX. However, we are still unsure which system to choose (DALI & DMX or REG-LED controller).
We have created an initial draft and would like to hear/read your opinions...
What could be improved here? Which system would you recommend for the lighting? The spotlights in the kitchen and bathroom are Dim2Warm, and for the rest, we would like to use LED RGBW(W).
We look forward to your suggestions for improvement.
Alex85
28 Jan 2018 10:02
Green dot labeled "PIR" is an occupancy sensor. Circles with a cross represent lamps, as usual. The rest is explained in the legend.
28 Jan 2018 10:03
Alex85 schrieb:
Green dot with "PIR" is a motion sensor. Circle with a cross are, as always, lights. The rest is explained in the legend.
Thanks, then I'm out of here... You guys got this [emoji6]
Mycraft28 Jan 2018 10:32
The motion sensor in the living room will most likely not work satisfactorily. In the hallway, two should be considered, one at the front and one at the back.
The rest has already been mentioned: too much light in the hallway, etc. No motion sensor in the guest bathroom.
O
ONeill
28 Jan 2018 11:01
Mycraft schrieb:
The occupancy sensor in the living room will probably not work satisfactorily. You should consider installing two in the hallway, one at the front and one at the back.
I can completely agree with that. The occupancy sensor in the living room doesn’t work well for controlling the lights. I haven’t found a satisfactory setup for that. So the lighting there is controlled by scenes instead. The sensor is now used as part of the alarm system.
The same goes for the sensor in the hallway. I installed only one at the front, and when we come from the living room, it’s always a bit dark until the light turns on. [emoji16] Learned something new there, but I’m still working on a solution—maybe occupancy sensors connected via LAN/Wi-Fi or something like that [emoji6].
Mycraft28 Jan 2018 11:21
ONeill schrieb:
PM via LAN/WLAN or similar
KNX-RF or another wireless system for building automation
O
ONeill
28 Jan 2018 11:30
I haven’t dealt with KNX-RF so far, but don’t I need a line coupler (200 euros) and also the occupancy sensor (maybe 100 euros)? Altogether that would be quite expensive if I don’t use KNX-RF elsewhere.
