ᐅ Optimal Temperature for a 300-Liter Hot Water Storage Tank?
Created on: 22 Dec 2017 09:39
Curly
We have a 300-liter (79-gallon) hot water tank and a gas heating system. The factory setting is 60 degrees Celsius (140°F), but our heating technician suggested that 50 degrees Celsius (122°F) would be sufficient. What about legionella bacteria? We certainly won’t completely empty the hot water tank (which supplies two showers). Our bathtub holds 220 liters (58 gallons), but it is used only occasionally. Is a temperature of 50 degrees Celsius (122°F) enough? What temperature do you keep in your hot water tanks?
Sabine
O
ONeill
22 Dec 2017 14:46
We have set it to 48 degrees, I believe. Because of legionella, there is apparently a heating program that runs at regular intervals. However, I still want to look into this more closely.
Oh, and we have an air-to-water heat pump.
Joedreck
22 Dec 2017 15:02
It is also important to regularly replace the water content. If you empty the storage tank daily, the temperature you set does not matter.
If you shower elsewhere and only shower at home 2-3 times a week, then you need a "safe" temperature.
Curly
22 Dec 2017 21:30
Joedreck schrieb:
If you shower outside your home and only shower 2-3 times a week at home, then you need a "safe" temperature.
Where can you shower "outside your home"?
Sabine
Saruss
22 Dec 2017 21:38
Curly schrieb:
Where can you shower "away from home"?
Sabine
For example, at the swimming pool, at work, or at the sports club.
merlin83
23 Dec 2017 21:28
Once a week at 70 degrees Celsius (158 degrees Fahrenheit), if I remember correctly, is recommended to prevent Legionella.
toxicmolotof
24 Dec 2017 09:13
However, a heat pump alone can’t manage 70°C (158°F). The electric heating element has to support it then.
