ᐅ Would you choose an air source heat pump again? I am looking for alternatives to air source heat pumps.
Created on: 9 Apr 2015 19:45
X
xycrazy
Hi everyone,
we are facing a decision regarding the heating system for our new build! The house has 160m² (1,722 sq ft) of living space plus a basement apartment with about 80m² (861 sq ft).
I have to admit, it’s not easy. Initially, I was leaning towards an air-to-water heat pump, then we considered pellets for a while, and now we are back to the air-to-water heat pump. Meanwhile, I’ve also read about trench collectors, which, if installed by yourself, can save the high investment costs of geothermal systems and make them similarly priced to air-to-water heat pumps.
You often read that air-to-water heat pumps only work well if everything is properly sized and the winter is relatively mild. I would be interested in hearing generally if you would choose an air-to-water heat pump again and what your monthly electricity consumption is. I’m concerned about heating with electricity. In the past, night storage heaters were criticized, and now we are supposed to heat with electricity again? Even though the air-to-water heat pump is much more efficient, I still feel uneasy because of the dependency on electricity prices and all the horror stories about very high energy bills.
By the way, we were recommended the Wolf BWL-1-A (outdoor installation). It is supposed to be very, very quiet but not exactly small. Does anyone have experience with it?
What would you choose as an alternative to the air-to-water heat pump? Gas? That’s basically not an option for me. I’m not comfortable having a gas line in the house, unless you have good arguments for it.
Other alternatives? Fireplace with buffer tank? Pellets?
Looking forward to your answers.
f-pNo11 Apr 2015 00:14
Saruss schrieb:
I hope the brine concentrate is inside the pipes.
That was good—but more precisely: if you mention it, it should be stated correctly.
Saruss schrieb:
The boreholes are sealed with something similar to cement (but a special material specifically for this purpose) to ensure as much surface contact as possible with the pipes, allowing effective heat transfer. There are significant differences in price and thermal conductivity here (unfortunately, better quality usually means higher cost).
As I said—the company has an excellent reputation in the area. Since they also operate in NW, you might have worked with them as well.
