Inspired by this thread:
where did things go wrong for you
and the following quote:
here’s my question: who has had everything go smoothly?
I don’t want to use the mentioned thread. Surely, nobody experiencing problems enjoys reading that everything is going perfectly for others.
Of course, we also had minor issues, but all were resolved immediately. For example, two window openings were built too large, the interior plaster was missing on the crawl space wall, the construction staircase was in the wrong place, and there was poor workmanship from the stair builder, which the flooring installer then corrected.
But overall, everything went great, which I mainly attribute to the overall setup:
Building in a rural area with individual contracts and a construction manager who has been doing this for a long time, knows all the companies personally, and when he says something, it gets done/made possible. Overall, only good companies with skilled workers who do proper work and don’t cut corners.
In addition, we thoroughly informed ourselves about each trade beforehand, knew exactly what we wanted and what could possibly go wrong. Depending on the phase, I was onsite daily or at least every three days and on call, which was fully utilized.
So with this arrangement, I would almost be ready to build again anytime.
MadameP schrieb:
That was the short version; I think everyone who is currently building can relate to it.
HilfeHilfe2 Nov 2019 11:20In our case, basically everything was completed. All open issues have been resolved. During the warranty period, there were problems with the pump, but that was a technical issue.
So far, everything is going well for us. There were only some issues with the exterior plaster on our added room because the waterproofing on top could not be completed before heavy rain, so the plaster got wet on both sides and did not adhere properly. However, the affected areas will simply be redone (fortunately, it’s only the small surface of the basement replacement room).
goalkeeper2 Nov 2019 13:31Nordlys schrieb:
Like with TUI, nothing to complain about. Then you haven't flown with them in a long time.
