ᐅ What settings should be used for the boiler and buffer tank system?
Created on: 29 Dec 2019 18:35
fonsi99
fonsi99
29 Dec 2019 18:35
Good day.
What buffer temperatures would you run our system at?
Attached are some details.
Pellet boiler 25 kW, buffer tank 1000 L (265 gallons), domestic hot water (setpoint 60°C (140°F), circulation 55°C (131°F)), solar thermal system
Multi-family house KfW 70 standard
Underfloor heating (flow temperature currently about 36°C (97°F) at 0°C (32°F) outside temperature, temperature difference approximately 5-6°C (9-11°F))
Multi-generation house (3 families, 6 adults, 3 children)
How would you set the upper and lower buffer temperature sensors?
Important note: the upper sensor was moved one step lower to increase the stratified tank volume available for domestic hot water.
Setting for upper buffer sensor?
Setting for lower buffer sensor?
Thank you for your suggestions.
I hope all data provided is sufficient.
