ᐅ Why Are the LED Lights Flashing in a New Build?
Created on: 22 Mar 2012 18:51
SuCeTi
I have switched to LED lamps in our new build. Now I noticed that some of them flicker, while others glow very dimly even when the switch is OFF.
Is there anything that can be done about this?
Above all, is this normal in a NEW BUILD?
Thank you in advance...
SuCeTi
23 Sep 2012 22:31
mottom schrieb:
In two-way and intermediate switch circuits, the lamp conductor runs parallel to the live conductor in the cable. This causes voltage to be induced in the lamp conductor (when the switch is off). This small voltage/power is enough to make the LED flicker or glow dimly. Branded light bulbs have a built-in component that prevents this.
However, this also happens with a regular light, meaning a lamp with a standard switch.
Cascada24 Sep 2012 13:57
mottom schrieb:
In two-way and multi-way switch circuits, the lamp conductor runs parallel to the live conductor within the cable. Because of this, voltage is induced in the lamp conductor (when the circuit is off). This small voltage/power is enough to cause the LED to flicker or glow faintly. Branded light bulbs include a component that prevents this.
that makes sense. With the branded lights, there was no problem, just as with the original halogen spotlights. Meanwhile, I have also tried Chinese SMD LEDs – they don’t flicker either.
Regards...
