I have a question that has been on my mind for a while, and I hope to get some practical insights or explanations here. Why do Malm nightstands from IKEA squeak even though they seem to be assembled correctly?
I have really followed all the instructions, tightened all the screws, and nothing appears to be loose. Still, when moving or slightly tilting the nightstand, there is an annoying squeaking noise, which probably comes from the movement of the individual parts or joints.
Are there common causes that are often overlooked despite proper assembly? Perhaps material properties, friction between wood and metal, or incorrect storage?
I would really appreciate detailed assessments, as I am also considering how to permanently eliminate this squeaking without having to take the furniture apart or treat it roughly.
lejesin schrieb:
My recommendation: For rotating joints, I would try to protect the contact surfaces with self-adhesive felt or thin plastic fiber mats.Thanks for the tip!
It’s becoming increasingly clear to me that with such furniture, it is almost inevitable to make some adjustments with a few aids after assembly.
My questions to the community now:
Which material is best suited here – felt, foam rubber, or special adhesive tape? And is there any experience regarding how long such measures last?
Also: What about maintenance? Is it necessary to redo these measures more often if the furniture continues to settle or shift over time?
Vinplo50 schrieb:
Which material is best suited here – felt, foam rubber, or special adhesive tape?Hello Vinplo50,
In my experience, felt pads have proven very effective because they reduce friction and adhere well at the same time.
Foam rubber can have a similar effect, but it tends to deform under constant pressure and loses stability.
Special double-sided adhesive tapes can help, but sometimes they come loose again due to temperature changes.
Durability obviously varies, but an annual check and, if necessary, reapplying felt pads or some lubricant is usually sufficient.
Good luck with your experiments!
I'll jump back in briefly:
For those who want to try using wax: it’s best to use solid beeswax without additives. Candle wax can help but sometimes has a strong smell.
And: apply it carefully—after a while, you can easily wipe off any excess wax.
Sounds almost like DIY with a wellness twist. 😉
