ᐅ Who is familiar with spray sealants for KALLAX fronts?
Created on: 30 Aug 2023 08:14
Finetra
I am currently looking into surface treatments for my IKEA KALLAX fronts and came across the topic of spray sealants. I’m interested to know if anyone has experience with spray sealants specifically for the fronts of the KALLAX shelving unit.
My main concern is achieving durable protection and a surface that is as resistant as possible, without significantly altering the appearance of the fronts. Could you recommend any products that work well, explain the ideal application process, and advise what I should pay attention to when preparing the surface?
I look forward to your tips and detailed experiences, including potential pitfalls or long-term effects.
Finetra
30 Aug 2023 14:03
kasan schrieb:
How much does the original look bother you if sealing causes a surface change?
Thank you for the important question. I want to preserve the appearance as much as possible. The high gloss finish should remain visible; matte or satin finishes would be my second choice.
I understand that this may be somewhat more challenging to achieve, but a protective clear coat that is barely noticeable would be ideal.
I will definitely test before doing a full treatment, perhaps on a rear surface area.
Nakar33
31 Aug 2023 08:42
Good morning everyone,
I wanted to share an important tip: especially with high-gloss foil coatings, I often use an additional adhesion promoter (primer), specifically designed for plastic surfaces.
These adhesion promoters are usually clear and thin, significantly improving the adhesion of the subsequent spray sealant and helping to prevent peeling.
There are also special sealants made specifically for “painted plastic surfaces,” which are generally UV-resistant as well.
@Finetra: If you decide to use such an adhesion promoter, it could make your project much more durable.
Please let me know how your practical test turns out—I’m very interested in the results!
Finetra
31 Aug 2023 10:07
Hello Nakar33, thanks for the tip!
I will first do a small test with a primer and a polyurethane spray sealant. I will get back to you with feedback once I have tried it.
In the meantime, thanks to everyone for the detailed tips and recommendations. I now have a good overview of what I need to consider and which products are suitable. 🙂
