ᐅ Which tasks should be carried out by an external structural engineer?
Created on: 15 Feb 2018 09:23
Herr Stein
Herr Stein
15 Feb 2018 09:23
Hello Everyone,
We are now close to signing a purchase agreement for a plot of land. I am starting to think about the next steps. For a long time, I had the following plan:
- independently obtain offers from 5 to 6 home builders
- review the offers with an expert and select the best one for us
- commission the chosen builder to carry out the construction
- hire an expert for independent construction supervision
I have already found an expert I would consider for construction supervision based on recommendations from others. The expert is a civil engineer and offers almost the full range of services for home construction – consulting, planning, tendering, awarding contracts, and construction management (he has been personally active in all these areas).
Now I am considering that the architects at the home building companies may primarily represent the interests of the builder and might not be motivated to design a house offering the best value for money – the main thing being that we build with them. Also, the offers might not be directly comparable because each company applies its own standard for all unspecified details.
Therefore, I thought about asking the expert about possible optimization options for the house design. However, he would likely charge this as a planning service, so the question arises whether it might be more sensible to do the house planning directly with the expert. In this option, the plan would look like this:
- plan the house with the expert, probably up to the creation of detailed specifications (bills of quantities)
- obtain offers from home builders based on these specifications
- and the rest as above...
I have the following questions:
- Is the second option significantly more expensive than the first, or would the builders offer lower prices because they no longer have to provide planning services?
- Is the potential savings from good planning enough to justify the additional cost of having the expert do the house planning?
- Which approach do you consider more reasonable? Where would you draw the line between what the expert does and what the home builder is responsible for?
Best regards, Herr Stein
