We are currently planning the construction of a solid brick house (urban villa with 160 sqm (1722 sq ft)), with two full floors plus a basement, without KfW funding. The standard option with the general contractor includes 36.5 cm (14 inches) porous S9 bricks without integrated insulation (Lambda value 0.09) with a two-layer plaster, no external thermal insulation composite system (ETICS) => U-value 0.23 W/(m²K).
Now we have the option to choose TV7 bricks (Lambda value 0.07) with integrated insulation instead, for an additional cost of nearly 5000 euros => U-value 0.23 W/(m²K).
Is this additional cost worth it?
It is also not yet decided whether to install a ventilation system with heat recovery (additional cost 7000 euros). Our concern here is not the comfort it provides but really the efficiency and cost-benefit factor. Is a ventilation system really necessary to avoid moisture problems? I am not asking about the comfort of ventilating three times a day, but rather whether anyone has experienced mold issues in a relatively new house due to the absence of a ventilation system, especially if windows were only opened once or twice occasionally.
Thank you in advance for your information and opinions.
Susanne N.22 May 2019 11:23Since we are buying a plot of land near the railway, I want to somehow reduce the noise. I want to have some quiet inside the house. Therefore, I would like to know which building material is best suited for this purpose. (I have read that aerated concrete is not good for sound insulation).
Susanne N.22 May 2019 11:49Nordlys schrieb:
Sand-lime brick.S
Susanne N.22 May 2019 14:00Nordlys schrieb:
Exactly. It has mass instead of air, which dampens sound, and is combined with an external thermal insulation composite system or facing brick.S
Susanne N.22 May 2019 14:04Thank you very much for your reply. Do you happen to know if they are even better than filled bricks or not? And are they also expensive?
