ᐅ Which type of filler should be used for the underside of a concrete balcony?
Created on: 1 Jun 2022 10:28
alive&kicking
since we can’t find anyone to do the finishing plaster on the underside and upstand of our concrete balcony, it’s up to me! (looking forward to it!)
Situation:
- Concrete balcony with an upstand, generally good surface and straight
- Balcony railing will be mounted on the vertical upstand
- Some pieces of binding wire (from the reinforcement) are visible on the underside and are already corroding
Planned preparation:
- Remove binding wire
- Concrete primer (PCI 303)
- Drip edge (Knauf p385t)
Questions:
- Is there a way to seal the rusting binding wire pieces? (e.g., epoxy with quartz sand) Otherwise, mechanical removal would be the only option
- Which filler (preferably fine-grained) is suitable for this work? Also considering compressive strength, as the balcony railing will be attached at the front edge (after plastering, according to the metalworker)
- It should be a filler that is easy to work with and can be applied smoothly. For larger areas, could one use quick-setting plaster profiles?
I would be very grateful for any answers.
Situation:
Questions:
alive&kicking3 Jun 2022 10:37Thank you very much, jcan, for taking so much time!!
