ᐅ Which type of luxury vinyl flooring is recommended?
Created on: 27 Jul 2020 11:36
Heidi1965
Heidi1965
27 Jul 2020 11:36
In the living areas of our new build, we are planning to install a design floor. Less than a year ago, I moved into a new build office where the same design floor was installed. I really like it, and despite office chair wheels and public foot traffic, I find the floor flawless. It belongs to abrasion class T and has a colorfastness rating of 6 or higher. Price: 29.90 €/sqm (3 USD/sq ft approx.). It doesn’t seem expensive to me. Is this type of floor recommended for residential living areas? With underfloor heating, is it possible or advisable to place a carpet on top, or is that not recommended?
Tolentino27 Jul 2020 11:39
That probably depends on who you ask. My heating engineer says no. The floor supplier says, of course. The answer is the same as with the question about floating installation.
I am currently doing some research myself. I have already decided for me, if possible, not to use HDF substrates, because if moisture gets in, it can cause internal decay.
Heidi1965
27 Jul 2020 11:42
What exactly are HDF joists?
Tolentino27 Jul 2020 11:45
HDF = high-density fiberboard = high-density fiberboard
Basically, glued wood chips.
It is often used as a substrate panel to prevent thin plastic from warping. But since it is ultimately wood-based, it does not handle moisture well, which is actually a key advantage of vinyl flooring.
So for me (if you have accepted the idea of plastic as a floor covering in living areas at all), only solid plastic flooring makes sense. You can even install that in the bathroom.
nordanney
27 Jul 2020 11:46
Heidi1965 schrieb:
Is this recommended for residential use?
“Plastic” for 30€ on the floor? No, I wouldn’t recommend that.
Tolentino27 Jul 2020 11:46
Yes, that is a point I still don’t quite understand. The material is usually too expensive and should be much cheaper.
