ᐅ Which acid-free cement residue remover should I use?
Created on: 6 Mar 2020 17:21
Golfi90
Golfi906 Mar 2020 17:21
Hello everyone!
Which ACID-FREE cement residue remover would you recommend for cleaning newly installed tiles?
I look forward to your recommendations!
Katdreas
7 Mar 2020 00:38
I currently have a cement residue remover from the hardware store at the construction site but am hesitant to use it... I’ve read a lot about it online and spoken with tilers and tile suppliers. It’s said to be the only thing that really works.
KlaRa12 Mar 2020 13:08
While mortar clumps can be chipped away, a "film" is known to be just a very thin dried layer. Naturally, it is alkaline and can therefore primarily only be removed with acidic cleaners.
If you are concerned about chemicals, you should, for example, avoid COLA. A litmus paper dipped into the beverage shows a pH value of 1 (strongly acidic).
So (this is meant seriously) take a small bottle of COLA, pour it over the affected area, wait about 10 minutes, and then blot up the dirty liquid with a cloth. Rinse afterwards with clean water, and you will see: the cement film is gone!
Best regards, KlaRa
