ᐅ When to Scratch Coat Render
Created on: 30 Oct 2010 14:02
Mari
Mari
30 Oct 2010 14:02
I recently plastered my first small wall using a scratch coat finish. It looks really perfect, but there was also some luck involved. I’m still not sure about the ideal timing for smoothing with the foam float.
I had the problem that I rubbed some areas completely flat, even though I didn’t apply much pressure.
Substrate: Primed cement-lime plaster.
My question is: After how many minutes (approximate) should you start smoothing, and how long should you continue smoothing?
Thank you in advance for your help.
Frank
schwarzmeier
12 Nov 2010 09:34
Apply mineral render evenly to grain thickness and move it so that the grains roll or tip, depending on the type.
