ᐅ What common mistakes occur when assembling the IKEA Brimnes furniture, and how can they be avoided?
Created on: 27 Jul 2022 09:23
mielka
Hello everyone, I am planning to assemble my IKEA Brimnes wardrobe soon and want to make the process as smooth as possible. Since I’ve heard that assembling the Brimnes often involves mistakes that make the process more difficult or cause parts to not fit properly or limit functionality, I am especially interested in the following: What common errors do you encounter when assembling the IKEA Brimnes, and how can they be specifically avoided? I am curious to know if there are typical pitfalls during certain steps or if particular tools and techniques have proven to be especially helpful. Maybe you also have tips on how to use the instructions most effectively or which parts should be carefully checked before starting.
GiRoyce
28 Jul 2022 09:50
For clarity regarding the instructions: The Brimnes manual is quite well designed, but it assumes a basic level of DIY understanding. Some symbols and steps can be easily misunderstood if you are inexperienced.
My tip is to flip through the entire manual before starting assembly and to consciously review each construction phase – this helps create a sense of the correct order. It’s also very helpful to follow the instructions step by step during assembly and not to skip ahead prematurely.
Here’s an important note: Screws and wall plugs are often intended for single use only. If a screw becomes stripped anywhere, it’s essential to replace it or drill a new hole; otherwise, the stability will be significantly compromised.
A word about tools: A small file or sandpaper can be useful if wooden parts fit a bit too tightly.
