cartuning2413 Aug 2012 19:04In this hole, a nozzle can be installed that is activated when flushing. It sprays a strong jet of water into the toilet bowl to flush it thoroughly. These toilets are commonly found in the USA.
perlenmann14 Aug 2012 07:21cartuning24 schrieb:
These toilets are mostly found in the USA.It seems not only the portions are larger there.
perlenmann14 Aug 2012 13:48As long as no high-pressure cleaner is connected that could cause damage!
*End of daydream*
*End of daydream*
andreas9 schrieb:
I won this new toilet bowl on eBay. Inside the bowl, where the water will later stand, there is a strange small hole about 2cm (0.8 inches) in diameter (see picture).
What is this hole for?
What additional materials are needed to use this hole?
Regards, AndreasHello Andreas,
You can usually get these nozzles at specialized retailers (e.g., Richter and Frenzel) or order them online.
Just try searching for them.
Stefan
