ᐅ Vertical wooden boards expand
Created on: 14 Aug 2024 17:12
knock88
knock88
14 Aug 2024 17:12
I have a carport. The basic frame is made of steel. Between the posts, we inserted boards vertically into U-profiles. These boards expand in winter and contract in summer, so in summer I have a gap of about 8cm (3 inches) between the board wall and the roof edge.
How can I close this gap in summer and relieve pressure in winter when the boards expand again?
Do you have any solutions or ideas?
Thanks
Jesse Custer
15 Aug 2024 08:09
You cannot prevent the actual process, so in the end, the only option is a continuous cladding that simply covers this area visually...
elminster
15 Aug 2024 09:40
Are you sure that the boards contract in summer? Don’t they actually expand? Or do they warp?
Nida35a15 Aug 2024 13:54
elminster schrieb:
Are you sure that the boards contract in the summer?
The boards expand slightly, while the steel frame expands significantly, which makes the boards appear to shrink.
knock88
15 Aug 2024 14:36
Thank you for your responses.
I think wood absorbs moisture in winter and expands. Metal contracts when cold.
I will install a trim panel.
