ᐅ Use 8/16 mm gravel as a capillary-breaking layer?
Created on: 23 Mar 2018 08:49
rob.leipzig
rob.leipzig
23 Mar 2018 08:49
Yesterday, I read a lot about capillary break layers. There seems to be some debate about whether they should include fines or be free of fines. Gravel with grain sizes of 8/32 mm (0.3/1.25 inches) or 0/32 mm (0/1.25 inches) is recommended.
Is it also possible to use gravel of 8/16 mm (0.3/0.6 inches) as a capillary break layer?
Furthermore, I read that gravel cannot be compacted. Does that mean you pour a layer of about 20 cm (8 inches) of gravel, place a membrane on top, and then pour a concrete slab of, for example, 25 cm (10 inches) above it? Is there no risk of settlement of the gravel layer?
Thank you very much,
Robert
Deliverer
23 Mar 2018 11:56
Regarding the second question: I am currently compacting over a gravel layer that will hopefully be 20 cm (8 inches) thick in the end. This compacts quite a lot. In my case, only paving will be laid on top. I believe the gravel size is 0/32.
