Hausbau Schweiz8 Jun 2008 21:22Hello,
I want to plaster drywall sheets on the ceiling. Are there any tips for achieving a good result? Which joint compound do you recommend? Do I need any special tools?
Thanks for the help
Hausbau Schweiz
Thanks for the help
Hausbau Schweiz
Flying-Spark12 Jul 2008 23:25Hello!
I can only agree with the previous commenter. Of course, you can mix the joint compound yourself. I think a bonding plaster based on gypsum should also work for this. The most important thing is to sand it well afterward so that the surface is 100% smooth, and no seams, waves, or irregularities show through the wallpaper.
It's actually quite simple—I did it for the first time when I was 15 and got perfect results. One more tip: be generous when applying the compound; it's better to put on a bit too much than too little, as the excess can be sanded smooth. I would use a straight edge for leveling; this is the easiest and fastest method compared to using a spatula.
Flying-Spark
Flying-Spark
