Micha&Dany1 Mar 2012 20:53Hello Forum!
This time, I have a question about window frames. A supplier recommended that I don’t go with the standard thickness of 70mm (2.8 inches) for the window frames, but rather opt for 88mm (3.5 inches). In both cases, the windows are triple-glazed.
Do thicker window frames really offer any advantages?
Are there any drawbacks, apart from the slightly higher cost?
Thank you very much for your help!
Micha 😎
Micha 😎
Micha&Dany schrieb:
Hello forum!
This time I have a question about window frames. A supplier recommended I don’t choose the standard thickness of 70mm (2.8 inches) for the window frames but rather go for 88mm (3.5 inches) instead (the windows are triple-glazed in both cases).
Are there any disadvantages besides the slightly higher price?
Thanks a lot for your help!
Micha 😎Hello!
The benefits are not directly due to the thickness itself.......
But with a wider frame
- you can achieve better insulation values
- you get more stability
- upgrading for sound insulation is possible.
Actually, I would have thought that 70mm (2.8 inches) frames aren’t even offered anymore with triple glazing.
When comparing Uw, Ug, Uf, and g-values, don’t forget about aesthetics and security 🙂.
TomTom1.
