ᐅ The terrace door sash can no longer be opened.
Created on: 30 May 2021 21:00
Andre77
Andre77
30 May 2021 21:00
Hey,
maybe someone can help with a solution:
Since today, one sash of the patio door no longer opens — the one with the handle. The handle is in the upright position, which normally means tilt, but the sash is pressed against the frame, so it won’t tilt. Turning the handle left to the horizontal position to open it also doesn’t work. At the top left corner, the sash is resting on the frame and can be pushed away slightly, so it seems it didn’t fully close there...
I’m a bit puzzled at the moment. The neighbor also took a look but didn’t want to use any force.
Thanks for any feedback!
rick201830 May 2021 21:09
It sounds like it was opened in tilt position. Sometimes it helps to close it, press it in the corner, and play around with the handle. Then close it completely.
Fingers crossed. It was also still warm. It could be that the door is slightly warped as well.
