ᐅ Appropriate Lighting
Created on: 8 Nov 2012 21:14
Terje
Terje
8 Nov 2012 21:14
I have not yet found a suitable ceiling light for my bathroom. The problem is that this is a prefabricated house and there is insulation material in the ceiling.
Ideally, I would like to use small, flat halogen recessed spotlights, but these get hot. Maybe there are some that come enclosed in a housing. Does anyone have any knowledge about this, or how have you solved this problem?
Regards
karliseppel
9 Nov 2012 08:21
Well, how should I put it...? It’s best to plan something like this in advance.
For your issue, there are heat protection spacers available for hollow core slabs. However, it will probably be quite a challenge to embed the associated transformer in the insulation layer from below in a way that allows inspection and is fire-safe.
To minimize heat generation, you can nowadays also use LEDs effectively; just make sure to check the lumen output and the beam angle of the spotlights.
Terje
12 Nov 2012 21:44
I was not able to plan in advance because this is a renovation. However, I have now realized that I can access it from above (upper floor). I have read that there are Fermacell boxes for thermal insulation, but I don’t know where to source or buy them.
Midnight
5 Dec 2012 15:13
It's best to look around in furniture stores or online shops (on Amazon, etc., etc.). Fortunately, tastes vary, so no one can give you exact recommendations.
