ᐅ Retrofit Installation of a Roller Shutter in an External Thermal Insulation Composite System (ETICS)
Created on: 13 Apr 2021 08:54
Mbk84
unfortunately, we did not install a roller shutter on one window and would like to add one now. Thanks to permanent home office, the room is now being used differently than originally planned and therefore needs darkening for the summer.
The roller shutter box to be installed is 14x14cm (5.5x5.5 inches), and the external thermal insulation composite system (ETICS) is 17cm (6.7 inches) thick. My idea was to cut out exactly this 14x14cm (5.5x5.5 inches) section from the ETICS above the window and then install the roller shutter box in this space. This would leave about 3cm (1.2 inches) of ETICS remaining, and I wouldn’t have to do anything on the facade. Essentially, this is the same setup as with the other roller shutters.
Is this a reasonable approach? Or would this cause significant issues regarding insulation or thermal bridging? THANK YOU VERY MUCH IN ADVANCE 😀
Here is a schematic of my plan:
Mbk84 schrieb:
Well, not really expensive. Around €200 for a roller shutter plus motor seems quite reasonable to me for a permanent solution. I can install it myself. Stylish clamp-on options like those from Blinos, for example, are definitely more expensive?!
What do you mean exactly? The box is placed on the rails first and then simply pushed up into the cavity from below. Then the rails are screwed in place. Well then, good luck! Please share photos of the result.
Mbk84 schrieb:
What do you mean by that? The box is placed onto the rails first and then simply slid into the cavity from below. After that, the rails are securely screwed in.aero2016 schrieb:
Well then, good luck! Please share some photos of the result.No, please demonstrate it in a video!https://www.instagram.com/11antgmxde/
aero2016 schrieb:
Well then, good luck! Please share some photos of the result.If it's really of interest, gladly.
Mbk84 schrieb:
If it's really of interest, gladlyYes, but also regarding the process, not just the outcome.https://www.instagram.com/11antgmxde/
Where do you get the roller shutter from? We are also currently considering retrofit options for external shading. However, I haven’t been able to find any roller shutters for prices around 200€ (about $220).
