ᐅ Recommendation for Sprinkler System
Created on: 28 Apr 2020 11:11
HilfeHilfe
HilfeHilfe
28 Apr 2020 11:11
we have about 25 linear meters (approximately 82 feet) of grass, the rest has been replaced by stones. I'm annoyed by having to water the lawn with the mobile Gardena sprinkler and would like to install something along the edge.
What system would you recommend?
rick201829 Apr 2020 06:30
@HilfeHilfe happy to help. Whether it’s possible only from the edge depends on the shape and the area that needs watering. I recommend Hunter rotors with pressure-regulating housings. Where is the water coming from (cistern, well, faucet)? If you make a sketch of your property, we can continue planning...
M4rvin29 Apr 2020 07:17
I haven’t tried it myself yet, but the Gardena planner is reportedly quite good. In the end, you get a list, and then you replace the Gardena products with those from your preferred manufacturer...
I’m not a fan of stones; how about a “wildflower meadow”?
rick201829 Apr 2020 07:20
It only works to a limited extent. Also, you should be familiar with the basics (such as overwatering). Just answer the questions, and then you can start planning. This isn’t the first time this question has come up here in the forum...
