ᐅ How to Spruce Up KALLAX with Leftover Building Materials – Any Inspiration?
Created on: 28 Jun 2023 08:23
Bakau
Hello everyone, I would like to personalize my KALLAX shelves a bit and have been thinking about using old leftover building materials I still have around – such as broken tiles, wood offcuts, mosaic pieces, or small bricks. My question is: What creative ideas do you have for meaningfully and attractively integrating such leftover materials on or into a KALLAX shelving unit? It is important to me that the result is not only decorative but also practical, for example, as a shelf surface, privacy screen, or even as small drawer fronts. Are there any specific techniques you would recommend to securely and visually appealingly attach these materials? I look forward to your inspiration and suggestions!
Marlenepa29 Jun 2023 13:48I agree with the previous advice but would like to add that when using brick pieces and stone fragments, you should always ensure there are no sharp edges sticking out. This is especially important if the shelf is in a frequently used room, as it could otherwise be dangerous.
Additionally, for shelving, you can build a substructure with wood glue and nails to securely support the components. If you want to add color accents, a clear varnish is highly recommended—it enhances the colors of the building materials and protects against moisture.
I wish you the best of luck with your project!
Jensson schrieb:
Typical mistakes include insufficient fastening or incorrect material selectionThank you for the detailed response, Jensson. That helps me a lot, especially the tip about trying out a compartment to get a feel for the weight and fastening.
Genevieve schrieb:
that silicone often does not adhere well to porous bricksThat was also a consideration for me, to improve support with wooden battens or similar so that nothing wobbles or falls off.
Can anyone else share advice on the surface preparation process? I have read that some building materials need to be primed beforehand so that adhesive sticks better. Does anyone have experience with specific products? Thanks in advance!
