ᐅ Gaps in the exterior sealing of the windows
Created on: 10 Sep 2024 11:29
Jimy3435
Hello
There are cutouts in the exterior seals of all the windows, possibly made by the previous owner. I’ve attached a photo. The cutouts are always located at the top.
Does anyone know what these are for?
Thanks for your answers
Close-up of a white window frame with a screw next to a glass pane.
Close-up of a white blind with a medium gap, dark interior visible.
profil65
11 Sep 2024 20:43
Jimy3435 schrieb:
The window has two seals. One can still be seen from the outside when the window is closed, and one is located in the middle of the frame. The outer seal appears to be somewhat thicker and more robust than the one in the frame. Only the outer seal has the cut parallel to the frame, about 7cm (3 inches) long.
My guess is that the window has a third seal as well, located on the sash on the interior side.
Jimy3435
12 Sep 2024 06:10
profil65 schrieb:
My crystal ball says that the window also has a third seal, located in the sash on the room side.
The crystal ball is correct. But what is it exactly? Is it pressure equalization or (unwanted) forced ventilation?
profil65
12 Sep 2024 13:11
Jimy3435 schrieb:
The crystal ball is correct. But what is it exactly? Pressure equalization or (unwanted) forced ventilation?
If there are no gaps, holes, interruptions, or trickle vents (?), that could break through the central seal and the inner stop seal, it can only be pressure equalization, which has nothing to do with ventilation.
Notes:
Quite a few laypersons and "experts" do not recognize trickle vents... this is especially true for the new models from one manufacturer.
Unfortunately, trickle vents are also often installed incorrectly (i.e., not according to the manufacturer’s instructions)... for example, there may be too many or too large gasket cut-outs, or the opposite...
