ᐅ Mounting a stair safety gate without drilling into the stair railing
Created on: 18 Apr 2016 14:57
abertram
Our little one is becoming mobile. It's time to install a stair gate on the upper floor. I don’t want to drill into the new staircase to attach the gate. A pressure-mounted gate is also not an option due to the tripping edge. Do you have any tips on how to solve this problem?
Regards,
Alex
abertram
18 Apr 2016 16:25
Thanks, everyone! I like Geuther. I will order it right away and give it a try.
Alex
Saruss
18 Apr 2016 18:33
I have been using 3 Roba units for 2 years now and am quite satisfied. I believe these devices will last for another 1.5 years, after which we won’t need them anymore.
Mycraft18 Apr 2016 20:44
As fate would have it, I am using both.
Uwe8219 Apr 2016 00:01
I found those very impractical at friends' houses because I always ended up pulling it out when opening. We have had Geuther for 3 years, and it works perfectly with one hand.
Musketier19 Apr 2016 06:50
@Mycraft
But this is not the Geuther swing gate for stairs.
With yours, there remains a trip guard strip at the bottom when opened, right?
Mycraft19 Apr 2016 08:56
It is the "easy lock." If you want to install it without drilling at all, you can only use a strip at the bottom, which does not cause any inconvenience since it hangs on the step. Therefore, the roba at the bottom is drilled directly into the wall.
