ᐅ Scratches on the Kallax After a Dog Visit – How to Make Them Less Visible?
Created on: 14 Mar 2020 07:38
lexanderso
I recently noticed some scratches on my Kallax shelf, which seem to have been caused by my dog. Specifically, these are superficial marks on the painted surface, likely made by my dog’s claws. My question is: What methods or products would you recommend to make these scratches as invisible as possible without having to sand down or repaint the entire shelf? It’s important to me that the solution is easy to apply and ideally does not require strong chemicals. Has anyone had experience with special wood care products, wax sticks, or similar items that work well on Kallax (birch finish)? Thanks for your suggestions!
lexanderso schrieb:
Does anyone have experience using paint pens on melamine surfaces or laminate coatings?Yes, I have some experience with this, so here is a brief guide:
1. Preparation: Be sure to clean the scratched area (using a slightly damp cotton cloth) and let it dry thoroughly!
2. Product selection: Choose a paint pen that is specifically marketed for melamine or laminate surfaces. This helps prevent chipping.
3. Application: Apply the paint very thinly and allow it to dry completely. If needed, you can apply several thin layers—but avoid applying too thickly.
4. Finishing: You can adjust the transitions using very fine abrasive pads or sandpaper (e.g., grit 600).
Common mistake: Applying too thick a layer can cause unsightly build-up or the paint to crack and peel later. Make sure to follow the recommended drying times.
In summary: With patience and the right paint pen, this works quite well. Ideally, combine it with a color-matched touch-up pen before applying a clear coat to ensure the color is correct.
