ᐅ Rotary dimmer insert for flush mounting in new construction
Created on: 16 Dec 2014 09:48
HilfeHilfeH
HilfeHilfe16 Dec 2014 09:48Hello,
My wife wants to have a dimmer installed. We are building a new house. Now you can buy the dimmer module with or without a two-way switch.
What exactly is a two-way switch? I couldn’t fully understand it from the information I found online…
HilfeHilfe16 Dec 2014 10:25Jochen104 schrieb:
How many switches are there for the lamp? You usually need a two-way switch if you have more than one switch controlling the lamp. Only one... Great! So that fits.
Thanks
Doc.Schnaggls16 Dec 2014 10:28Jochen104 schrieb:
You usually need a two-way switch if you have more than one switch for the same light.I always thought that a two-way switch setup involves exactly 2 switches. When there are 3 or more switches for the same lighting point, isn’t that called a series switch or a push-button switch?
V
Vespa Fahrer26 Jun 2015 14:37Or you have an impulse relay "eltako," then it also works with push buttons.
