ᐅ Roof insulation for KfW 55 standard: what is the most cost-effective option?
Created on: 26 Jan 2020 01:12
Peter Hausbau
Peter Hausbau
26 Jan 2020 01:12
what is the most cost-effective roof insulation (above-rafter / between-rafter) for a KFW 55 house, if you exclude polystyrene and similar materials?
Best regards, Peter
Schnitt durch Dachkonstruktion mit Dämmung, Holzträgern und Gebäudehülle
boxandroof
26 Jan 2020 01:36
The most cost-effective construction is probably with 20cm mineral wool. However, since insulating the roof is relatively inexpensive, it is often better insulated, with savings made elsewhere.
Peter Hausbau
26 Jan 2020 11:02
That means that continuous insulation above the rafters is definitely more cost-effective than insulation between the rafters. It then mainly depends on the thickness of the insulation and the material (glass wool / stone wool).
boxandroof
26 Jan 2020 11:27
The most cost-effective option, I would argue, is insulation only between the rafters with a thickness of 20cm (8 inches). Whether this makes the most sense within the overall concept is another matter.
