ᐅ Risk to Water and Drainage Pipes from Tree and Shrub Roots
Created on: 9 Feb 2015 18:35
willWohnen
I have read that tree roots can cause significant damage to water or sewage pipes. However, these issues mostly come from older houses, where the pipes were often made of clay. The problem usually starts when small leaks allow water to escape, attracting roots that then grow toward the source.
Additional note: not only trees are potentially "dangerous," but also shrubs like lilac or butterfly bush.
In our case, the utility lines—electricity, internet, water, sewage—unfortunately run diagonally across the front yard. I would like to plant bushes or trees there. Our water pipes are made of plastic.
Apparently, root barriers made from sufficiently thick membranes can be installed. However, most of our lines have already been backfilled. I don’t want to make a mountain out of a molehill or spend money unnecessarily to dig everything up and install membranes (especially since I don’t know how to do that professionally). But I would like to plant my front yard with peace of mind and avoid having to excavate everything in 15 years.
It’s a complex topic. I am hoping for the following advice:
o Who has real, concrete experience with root-related utility line problems?
o Who has heard about this issue during their home and garden construction and possibly taken measures against it?
o Where could I turn to—what professional group, authority, or website has experienced experts on this matter?
Thanks and best regards
Starting from scratch! Today, my 4 m radius (13 feet) was taken away!!! The utility company needed to dig another trench. I’m outraged! No tree in this paved wasteland after all. oops:
I’ll plant evergreen shrubs and rose bushes, and I’ll let the forget-me-nots reseed on their own. So, I’m back in the club!
willWohnen19 Feb 2015 16:59@EveundGerd Sorry, that’s not a good idea. Japanese knotweed is a no-go because it has very aggressive roots that definitely damage pipes.
I’m also unsure about roses. I see them as an appealing alternative, but I believe they are deep-rooted as well. If I want to grow a large climbing rose against the garage, I wonder if that would work. If you find out more about the root systems of roses, please let me know...
MünchnerKindl19 Feb 2015 19:21Hello,
roses are likely to be difficult as well since they have deep roots.
From what you’re describing, I can already see my "flowering front garden" fading away.
In our case, the pipe runs right across the area.
I’ll have to look into what other plants might be suitable instead.
MünchnerKindl19 Feb 2015 19:26Quickly found:
Hornbeam, magnolias, willows, serviceberry, currant bushes, barberry, golden honeysuckle, hazelnut, privet, butterfly bush.
There should be something suitable here. Privet is also available as an evergreen.
I would not recommend hazelnut. We had it on the site. It’s a nice plant for the forest, where it can freely spread.
Thanks again!!!
Thanks again!!!
So, I took a closer look at the native serviceberry. It has shallow roots but requires a root barrier. 60cm (24 inches) deep and 1.20m (4 feet) in diameter. It grows as a shrub about 1 to 3m (3 to 10 feet) tall. The common serviceberry should also have a root barrier.
That should be the least of the problems. I will measure tomorrow to see if it fits.
