ᐅ Replacement of windows with an added partition wall
Created on: 10 Apr 2022 17:06
Robvoi79
Unfortunately, the kids managed to damage the lower middle pane of this window wall while playing around. The glass appears to be cracked on the inside but not completely broken through. However, I’m not entirely sure about that.
We have separated the fairly large room with a drywall partition to create two children's bedrooms (visible in the upper pane). This wall might now be an obstacle for replacing the pane.
However, I generally don’t have any idea how to replace a pane in a window wall like this.
Is it possibly feasible to replace the pane despite the wall being there?
Außenansicht eines roten Ziegelhauses mit breitem weißen Doppelfenster vor blauem Himmel
Robvoi79
11 Apr 2022 08:01
Unfortunately, it’s quite tight. The strip. Are those the crossbeams?
Robvoi79
11 Apr 2022 08:07
Now I know what the trim pieces are. YouTube is quite helpful.
However, I find it difficult to estimate whether I can fit them past the wall.
Otherwise, it doesn’t really look complicated. They are really just clipped in place.
Benutzer200
11 Apr 2022 08:25
It looks like you need to create a bit more space at the bottom. Then the glazing bead should come out.
Please do not pry it out with a screwdriver or similar tool. Use a thin putty knife or buy a suitable tool (a glazing tool) for around 5€.
gutentag11 Apr 2022 09:12
If you remove a side strip first, you might be able to pull out the top and bottom strips afterward. However, I doubt the pane will come out, as it looks very tight. Placing the wall directly against the pane, as you can see, was not a good idea.
I would cut back the wall area around the pane and then fill the space with a strip of polystyrene after installing the new pane.
