ᐅ Repairing Q3 plaster, filler compound, and primer
Created on: 29 Aug 2017 21:19
hemali2003
Hello everyone!
The interior of our house was plastered in Q3 quality—apparently quite decent (according to our building consultant). The walls appear very even, although the texture varies slightly in some areas. There are spots where the solid components (aggregate – fine sand?) of the plaster are visible on the surface, and other areas that look completely smooth—these smooth areas are slightly recessed (shrunk a little during drying due to lack of aggregate). But only minimally.
Now to my questions:
Is there a filler or putty that has this slight texture, which we could use to cover the “too smooth” spots? I’ve only found fillers that aim to make the surface very smooth—but that’s not what we want.
Should the primer be applied after filling, or possibly before?
We don’t want to fill and sand everything—we actually prefer not to have a perfectly smooth surface.
Thank you very much in advance!!!
hemali2003
30 Aug 2017 21:39
The plaster was applied, leveled, and smoothed while still damp or rather wet. It is already very even and, according to several professionals, can be painted as is (if you do not expect perfectly smooth walls).
hemali2003
30 Aug 2017 21:44
So-called trowel marks are not visible, which is apparently the main criterion for Q3. I have also often read online that Q3 can be omitted – that’s actually how I came across this.
