ᐅ Reliability of an energy calculation for KfW 55 – is it too high?
Created on: 20 Jun 2016 18:01
WT1987
For our new build with 2 full floors and a basement, we have now received a calculation for the entire KfW application. However, it seems to me that the numbers are being calculated quite high or may even be incorrect.
Some data about the house:
Is that the electricity consumption I should expect, or am I misunderstanding something? That seems very high!
Thank you in advance.
- Architect’s plan shows living area: ground floor 75m² (807 ft²) & upper floor 70m² (753 ft²) (difference due to open space)
- Clear ceiling height: ground floor 2.7m (8 ft 10 in) & upper floor 2.5m (8 ft 2 in)
- Basement is unheated, air-water heat pump located in the basement
- Attic is not developed
- Air-water heat pump with ventilation system including heat recovery
- The expert assessor calculates a usable floor area of 277m² (2,982 ft²), which seems very high to me! He then uses this to estimate electricity consumption and arrives at a final energy demand of 4,860 kWh/year
MarcWen schrieb:
That can’t be right, we are building a corner bigger and have a primary energy demand QP of 23.4 kWh. But per square meter, so the size is already factored out?
BeHaElJa schrieb:
23.4 kWh/m²a (?) - his is 31.6 kWh/m²a, which isn’t that far off..Well, we are building about 50% larger and have about 25% less primary energy demand QP.
So I would at least want to follow up on that.
