what is your opinion on buying recycled crushed stone for the house’s foundation slab? We need to overcome a relatively large height (1.2 m (4 feet)), and this could save a considerable amount of money. So far, I have heard mixed opinions but no real explanations.
What are your thoughts on this topic?
Stefan00110 Sep 2021 09:34HausTmMike schrieb:
Yes, it should all be specified in the structural calculations In your post, you only wrote: "first, lay down about one meter of fill sand"
That’s why I pointed out that it’s not that simple!
HausTmMike10 Sep 2021 09:36Stefan001 schrieb:
You initially wrote in your post: "just lay down about a meter of fill sand first."
That’s why I pointed out that it’s not that simple! Sorry, that wasn’t what I meant. This needs to be determined individually by a professional, either on site or through detailed planning.
nordanney10 Sep 2021 09:42Basically, recycled gravel is not a problem, but an opportunity to save money. Of course, proper planning is necessary to ensure everything works out in the end.
In commercial construction, it is common practice to demolish existing buildings and process the debris on site into gravel. This gravel is then used for backfilling.
And recycling is usually also prohibited in drinking water protection areas. This should also be taken into consideration.
O
Oraclefile10 Sep 2021 17:23Thanks in advance for the numerous replies. At first glance, this sounds very promising. Firstly, raw materials are reused, and secondly, it apparently saves a significant amount of money. According to our soil survey, the use of recycled aggregate is also allowed and should hopefully not pose any problems. Of course, the planning will be professionally handled on site, so I can’t say much more at this point. However, since two earthworks contractors we consulted, without knowing the site conditions, opposed the use of recycled aggregate, we were a bit surprised.
Assuming the soil survey and structural engineering report give the green light, is there nothing against using it?
Oraclefile schrieb:
According to our soil report, the use of recycled gravel is also permittedThat’s not stated in the report itself, but by the local water authority, which must approve it (for a fee). So part of the savings will be offset by that cost. I’m not bothered by the recycled gravel, but it does sometimes contain quite a bit of debris.
