ᐅ Properly Dividing a Plot of Land for a Single-Family House and a Duplex
Created on: 8 Jun 2019 23:14
hausbauer
I would appreciate your tips and advice regarding the following situation:
A plot of land with 1100m² (11,840 sq ft) is to be divided so that the following houses can fit on it:
Part 1 – Single-family house with approximately 160m² (1,722 sq ft) of living space (2 full floors, flat or shed roof) + garage/carport
Part 2 – Semi-detached house, each half with about 150m² (1,615 sq ft) of living space (2 full floors, flat or shed roof) + garage/carport
The access road is located at the bottom, on the south side. A 3m (10 ft) wide access path is to be created for the semi-detached house.
The site coverage ratio (floor area ratio) is 0.4, and the floor space index is 0.7. Additionally, the Bavarian setback regulations must be observed.
I am a complete beginner but imagine dividing it somewhat like in the attached sketch. Does this make sense? Are there any particular points to watch out for, or mistakes to avoid? How is it best to arrange garages/parking spaces for the semi-detached house? Does it even make sense to place the semi-detached house at the back? Would it be easier in terms of access and parking to move the semi-detached house closer to the street (option 2)? Which option is more cost-effective regarding shading and best use of space?
Thanks in advance for your answers!
Regards
Drei Grundrissvarianten: links ungeteiltes 1100 m², Mitte Doppelhaus und EFH, Rechts EFH und Doppelhaus
hausbauer
10 Jun 2019 17:40
Thank you both for the many suggestions. They have already provided me with plenty of material for my own thoughts and planning. Now, I will likely face an interesting mix of planning regulations, tax issues, and contract matters.
11ant10 Jun 2019 21:08
Hausbauer schrieb:
Now I’m probably facing an interesting mix of planning law, tax issues, and contract matters.
Would, subjunctive. That would be the case if you had the funds ready for developing the entire property. As I said, I see two other things ahead of you first:
1. Define clearly what YOU want to build on this land;
2. Make sure the landowner is willing to go that route with you.
Planning law)
Take your own single-family house. Whether the landowner subdivides the rest again or builds a duplex as a community property (e.g., homeowners association), that’s not your concern. Your own plans will keep you busy enough.
Tax issues)
All three or four homebuilders buy directly from the owner of the entire property, which is straightforward.
Contract matters)
Beware of the foolish idea of forming a demolition project company with the other homebuilders. Buy a property that is “already demolished.”
hausbauer
12 Jun 2019 22:39
11ant: Thanks for the advice, I will take it to heart. Following all the recommendations at once will be difficult in the current seller’s market, but I will try to limit my risk... or ultimately decide to walk away.
11ant12 Jun 2019 23:00
Hausbauer schrieb:
Trying to follow all advice at once will be difficult in the current seller’s market,
At least my advice to you is not overly complicated. Essentially, I have given you one piece of advice in two parts:
a. be clear about what you want
b. convey this idea to the current property owner.
