ᐅ Issue with the Renlig
Created on: 4 Sep 2012 12:33
Lilo_9316
Lilo_9316
4 Sep 2012 12:33
Hello everyone!
Since February, I have had a Renlig DW 60 in my kitchen.
So far, apart from a very high rinse aid consumption, it has worked well.
Starting today, it is doing the following:
When I switch it on, only the small light below the Eco indicator lights up.
If I hold down the Select button for a few seconds, all the lights come on again (as they normally do), and the machine can be started as usual.
After the wash cycle is finished and I open the machine, only the Eco indicator lights up again.
So it’s the same pattern.
What am I doing wrong?
fleptin
11 Sep 2012 10:50
According to the manual, this is not normal behavior. I would suggest disconnecting the power (unplugging and plugging back in or switching the circuit breaker off and on), as it might just be an electronic glitch. Otherwise, there is likely a defect.
I would then recommend calling the Ikea hotline for Electrolux devices. Your model has only been available since the 2010 catalog, so it should still be covered under the 5-year warranty.
