ᐅ Potential / Experience – Building Two Houses at the Same Time?
Created on: 26 Jul 2019 07:14
allstar83
We now have the opportunity to build two houses right next to each other (for us and my sister-in-law and brother-in-law).
What do you think, what cost savings could result from this, or which measures should be actively considered here?
We would be very grateful for any tips or shared experiences.
Thank you very much
- Same construction company to get a better deal?
- Potential savings on landscaping/exterior work?
- Coordinate site preparation?
Thank you very much
goalkeeper schrieb:
Everyone just told us that there isn’t much potential for savings.If middle houses are built with basements and end houses without, but both have different roof types, then that might be true. However, this is exactly where the greatest savings potential lies: building houses with and without basements side by side at the same time significantly reduces unnecessary extra work.https://www.instagram.com/11antgmxde/
goalkeeper26 Jul 2019 15:1611ant schrieb:
built at the same timeThat would be way too simple...
If you are working together on any topics, you should definitely set clear agreements in advance. We shared the temporary power distribution box, temporary power contract, toilet, water, and carried out the earthworks at the same time, which only caused problems. We also did not fence the plots individually, which turned out to be a mistake afterward because the contractors were not always clear—or did not care—about where things belonged. And when you have excavated soil from the neighbor on your property, it can be quite troublesome and cause friction, even if it was unintentional. We would not enter such a situation again.
allstar8326 Jul 2019 18:1011ant schrieb:
Are these only neighboring plots or is it a semi-detached house; and are the houses clones / mirror images or different?Not a semi-detached house, and the houses are probably different as well.
