ᐅ Plan bricks do not fully rest on the foundation slab – is the slab too small?
Created on: 30 Aug 2015 03:18
O
oggear51
The masons recently finished building the ground floor walls, but I noticed that on one side of the house the facing bricks extend about 1–2.5 cm (0.4–1 inch) above the base slab. I immediately measured the interior walls with a laser measuring device, and everything was correct inside. So now the question is, is it a problem that the facing bricks are not fully sitting on the base slab?
Thanks in advance
Thanks in advance
Bauexperte30 Aug 2015 22:11Good evening,
whether my answer will truly help you is hard to say, since you only know my profile, but neither me personally nor my work.
I can also answer your next question quite easily; however, I do not believe it will give you lasting reassurance. In my experience, you either need to place more trust in your construction manager or—what I consider more effective—invest in independent construction supervision.
Answers from a forum can be both correct and incorrect; there is often plenty of nonsense to read. They can never fully replace external professional expertise or provide lasting peace of mind!
PS: The slot, as well as others, will of course be closed before the exterior thermal insulation composite system (ETICS) is applied.
Best regards, Bauexperte
Bauexperte
Bauexperte
