ᐅ Plan the ventilation system before starting the structural shell construction
Created on: 16 Jun 2019 09:37
dobbelhaus
Hello!
Since I need to install ventilation systems with heat recovery for my new build (semi-detached house with 4 residential units), I am considering which option to choose and what measures I can take during the shell construction phase to ensure the system is implemented optimally and cost-effectively.
A central system seems more complex, as these units require some space and I need one system for each side of the semi-detached house. In addition, planning the rough-in installation is not straightforward. Estimated cost: 2 x 7000€.
A decentralized solution appears simpler. I plan to pre-drill a hole in a 499 x 365 x 249 mm (20 x 14 x 10 inches) aerated concrete block (Ytong) in each living room before the masons start laying the walls (according to DIN 160), to save the effort later on, which definitely won’t be easier or cheaper afterwards. This means 14 holes in total, one in each living room. Cost: 14 x 500€ = 7000€.
What do you think of my plan? Are there any important points I should keep in mind?
Thanks
Bookstar
13 Jul 2019 18:22
Duplex house is spelled with two p's, just like Paula.
micric3
13 Jul 2019 18:26
And what does that have to do with the thread?
11ant13 Jul 2019 23:39
Actually, it's about a semi-detached house, which you would then build using semi-detached construction methods.
boxandroof
14 Jul 2019 02:29
dobbelhaus schrieb:
Are there decentralized ventilation systems that are genuinely trouble-free (quiet), preferably ones that last a lifetime?
I would recommend listening to various decentralized units in person, as there are significant differences you can’t detect on paper, for example in startup behavior.
For a limited number of rooms, I would also prefer decentralized units per room and include their operation in the rental agreement. For owner-occupied single-family homes, a centralized system is more suitable.
