Hello everyone, I need some help.
Our neighbor has access to groundwater, and we can also use this water. Currently, there is a tap with two faucets; one faucet has our garden hose connected, which runs across the lawn to our property. Now we want to bury the whole setup underground. I’m not sure how a regular garden hose would hold up underground, so I’m thinking of using a PE HD pipe. We have a water tap in our garden where the garden hose is connected at the bottom, all using standard hose connectors.
How can I connect the PE pipe to the groundwater tap, and how can I connect the PE pipe to the water tap in our garden? Are there hose connectors available for PE pipe, or how should this be done?
meister keks27 Jul 2018 18:27Or you lay a 1kg (2.2 lbs) pipe in the ground and pull the hose through it; then, if it ever breaks, you can pull out the hose and push a new one through.
