ᐅ Paving a driveway – height considerations
Created on: 8 Nov 2021 12:33
Lowfox
I am currently renewing my driveway. So far, about 60 square meters (645 square feet) of old paving have been removed, and now new paving will be installed.
What I noticed is that there was sand beneath the old paving, and below that an extremely hard layer. I assume this is crushed stone (gravel) that was compacted very firmly about 40 years ago.
Unfortunately, this layer is uneven and not level in some places. Before spreading the 5 cm (2 inches) bedding layer of grit on top, I would like to have a smooth, level base layer. What do you recommend for this? I initially thought of adding more crushed stone, but I am concerned that I won’t be able to properly compact it into the existing base with a plate compactor. This layer is really hard, almost like concrete.
I was told that the bedding layer of grit should not be thicker than 5 cm (2 inches). But how can I best level out these uneven spots in the base layer to create a flat surface?
Thanks for your advice!
O
Osnabruecker
8 Nov 2021 15:29
Loosen and break up the existing 15 cm (6 inches) layer and leave it in place, supply additional material as needed, then possibly break it up again to mix the materials a bit. Then level it to the required height and compact it.
Do not remove any material (unless necessary due to elevation requirements).
Lowfox
8 Nov 2021 15:51
Understood. I’m not yet sure if I’ll do it that way. The chipping is a huge effort since it’s as hard as concrete and 15cm (6 inches) deep over 60sqm (645 sq ft). Maybe someone else has another option?
