ᐅ Interior partition walls showing horizontal cracking
Created on: 4 Jul 2021 12:36
marco2403
Hello, how is it possible that almost all non-load-bearing partition walls in my house have developed horizontal cracks overnight? The walls were built using 11.5 cm (4.5 inch) and 17.5 cm (7 inch) hollow concrete blocks. I know there are wallpapers that can hide these cracks, but I am concerned about the bathrooms that will be tiled. The structural engineer says these cracks can be caused by the sagging of the ceilings and are not a cause for concern. Should I believe that?
Beige wall with a fine horizontal crack line and a small marking line.
Light gray, slightly textured paper with a fine horizontal crease line.
Light gray concrete wall with a fine speckled texture and a horizontal crack line.
Nida35a5 Jul 2021 10:06
Plaster cracks with a width of 0.2mm (0.008 inches) are flooded over, and elastic sealing is applied at corners, ends, and joints.
marco2403
5 Jul 2021 10:16
These are not plaster cracks but wall cracks. The cracks can be seen from both sides.
