ᐅ Painting Textured Render After Application
Created on: 10 Sep 2013 00:48
Bauexperte
Bauexperte
10 Sep 2013 00:48
PhoenixDH schrieb:
We are considering using roll-on plaster for the walls (probably from Hornbach).
Sorry, but you are definitely going the "cheap route"...
PhoenixDH schrieb:
Can it be painted over afterwards, or will it turn out patchy? Because I always read online that it should be tinted in advance.
Find a skilled supplier of roll-on plasters—have them do the initial application, and later on you’ll only need a suitable roller for repainting... says someone who has been easily refreshing the roll-on plaster in their hallway with a new coat for over 20 years.
Best regards, Bauexperte
PhoenixDH
10 Sep 2013 05:11
What does this have to do with budget options if you want to do it yourself?
I will probably only get my materials from there. The manufacturer has not been determined yet.
But if I understand your answer correctly, it can generally be excluded.
Bauexperte
10 Sep 2013 08:19
PhoenixDH schrieb:
What does this have to do with a cheap approach if you want to do it yourself?
I will probably only source my material from there. The manufacturer is not yet decided.
First of all, it is a hardware store and not a building materials supplier, and secondly, I believe that textured plaster should be applied by a professional. It is something completely different from simply preparing a wall for wallpaper or paint.
PhoenixDH schrieb:
But if I understand your answer correctly, it can generally be painted over.
Yes, it depends on the roller used.
Der Da10 Sep 2013 10:09
I seriously advise you to try textured roller plaster first in a utility room or basement. You’ll quickly realize that it’s not as easy as it looks in the commercials.
We initially used roller plaster from Knauf. What a terrible mix…. You can’t apply it fast enough before it starts drying.
Especially if your building is still in the drying phase, it’s not the best time to use roller plaster. Besides the high costs, a professional painter will achieve a much better result than you will. And you can’t just remove roller plaster easily once it’s applied.
Wallpapering was our solution. Keep in mind that your house has about 600 m² (6,460 sq ft) of wall and ceiling area. That would mean nearly 60 buckets.
Diane
27 Sep 2013 12:52
Hi,
Unfortunately, we also had a bad experience with textured plaster in our stairwell :/ definitely not recommended!
PhoenixDH
27 Sep 2013 13:33
Yes, and what exactly was the problem?
