Unfortunately, we have moisture damage on both sides of the front door and the patio door. The house was built in 1998, and I purchased it last year. Last year, the side walls where there is no terrace or front door were sealed with a thick Botazit coating and Delta Drain Quadro dimpled membrane—so, the areas without tiles. I have attached two photos of the front door. Where could the moisture be entering, and how can I seal it? What further steps can I take?
Thank you for your help!
fini
fini
I have now received a quote.
It seems very high to me!
The area along the house is 8 meters (26 feet) long and about 35 centimeters (14 inches) deep.
Remove, store, cut, and reinstall patio slabs
Earthworks – excavation of the work area and backfilling
Waterproofing works
425.00 EUR
Materials: zinc sheet metal, roofing screws, primer coat, silicone,
Botazit 28 kg (62 lbs), KG pipe 7 meters (23 feet), Floormate 30 mm (1.2 inches), and
Delta Geo Drain
245.00 EUR
fini
Waterproofing works
425.00 EUR
Delta Geo Drain
245.00 EUR
fini
