I am interested in the typical measurement values for a heat pump with cooling function, as my values seem to be lower than expected. Shouldn't there be a difference between the supply and return temperatures? According to the heating engineer, the values are normal. The pump is a Waterkotte A1+ with deep drilling.
Indoor temperature: 21.7°C (thermometer)
Outdoor temperature: 29.8°C (pump)
Supply temperature: 21.9°C
Return temperature: 21.9°C
merlin66729 Jul 2013 13:21I did some research: If the construction methods of natural cooling do not differ significantly, there should be a second heat exchanger installed that operates directly without a refrigerant circuit. There should also be a few 3/2-way valves that switch back and forth between the modes.
