We have an additional balcony in our new build that was sealed with a membrane over the insulation. Around the balcony is a stone edging, against which the membrane is laid.
What is the best way to install flooring here using WPC decking boards? I would like to raise the decking to the level of the stone edging to create a flat surface. But how do you attach supports or pedestals in this case? Drilling into the membrane would probably be a bad idea ;-)
Or can this be filled with other materials and the WPC boards simply laid on top?
R.Hotzenplotz3 Dec 2017 11:20Alex85 schrieb:
When it comes to weeds, it’s mainly about the sub-base. You can design it accordingly. Currently, in the rental property, we have cobblestone paving with concrete joints, as far as I can tell, and nothing grows through it (though we get moss on top 🙂)Exactly. There must be no soil present. The question is whether it’s possible to fix granite ceramic tiles onto a suitable sub-base.
My concrete slabs on the roof terrace above my garage are laid on pedestals. These pedestals are height-adjustable, which allowed the substructure to be built with a slope while keeping the slabs level.
Rainwater and other runoff drain through the joints between the concrete slabs, and there is a drain in the garage roof that channels the water to the gutter.
Search term: pedestal balcony slabs
