ᐅ Installing Satellite and Underground Cables into the House
Created on: 21 Oct 2017 15:00
G-Star1988
The next topic in our house construction is the electrical work. I want to run three underground cables to the outside and four satellite cables into the house. Is it sufficient to just use a conduit and then fill it with expanding foam, or is that waterproof? Or do I need to use special sealing glands?
Thanks for your help
Bau-Schmidt21 Oct 2017 17:48Then PVC pipes will be sufficient for you as well.
G-Star198821 Oct 2017 17:54B
Bau-Schmidt21 Oct 2017 18:02Then you better use Kabuflex pipes. They are suitable for underground installation.
G-Star198821 Oct 2017 18:06Ok, are these harder than the ones I also use as conduit?
My pipe is labeled "highspeed VDE" and is relatively stiff and durable.
Bau-Schmidt21 Oct 2017 18:21That does not necessarily mean that they are suitable for underground installation.
G-Star1988 schrieb:
... next, I’m approaching the electrical topic in our house construction. I want to run three underground cables outside and bring four satellite cables into the house. I assume you already know that installations on electrical systems are reserved for licensed electricians according to NAV § 13?
Is it enough to just use an empty conduit and then seal it afterward with expanding foam for wells? Is that waterproof, or do you have to use special cable glands? Certainly not with pressurized water.
If you have to rely on forum experience for details like this, it raises the question about the safety of the power and satellite cables.
By the way: conventionally directly grounded rooftop antennas rank significantly higher in safety compared to garden or outdoor antennas. Grounding and equipotential bonding are integral parts of the electrical system.
