ᐅ The KALLAX back panel keeps falling out – is it better to glue it?
Created on: 30 Apr 2015 18:07
beman
Hello everyone, I have a small but constantly annoying problem with my IKEA KALLAX shelving unit. The back panel regularly slips out of the groove, no matter how carefully I use or load the shelves. This especially happens when the shelves or baskets are moved frequently or if there are slight vibrations. I’m wondering if it would be a good idea to fix the back panel with some adhesive to prevent it from slipping out all the time. Has anyone had experience with this? Or is there perhaps a better solution than just gluing it? It’s important to me that the structure is not damaged and that the back panel can still be removed later without too much difficulty. Thanks in advance for any tips!
Brian
1 May 2015 14:02
beman schrieb:
Are there specific adhesive tapes that are better suited for this purpose? At least somewhat durable against stress and not too aggressive on the surface?
Yes, there are so-called "furniture tapes" or "double-sided foam tapes" that are somewhat elastic and adhere well to wooden surfaces without causing damage.
You can find such tapes, for example, at hardware stores. It is important that they can be removed without leaving residue – this applies to some 3M brands that offer products specifically designed for delicate surfaces.
Alternatively, you can also use narrow, transparent hook-and-loop strips, which also hold well and can be removed and reapplied multiple times. Although these are more expensive, they offer maximum flexibility.
bapeo39
2 May 2015 07:53
beman schrieb:
One more question to the group: Are there specific adhesive tapes that are better suited for this purpose?
I usually use these "Tesa furniture tapes." They are easy to remove and provide enough adhesion. Important: Clean the surface before applying the tape.
Muso4
2 May 2015 08:30
One last note: When using adhesive, also consider the long-term effects. Some adhesive tapes dry out and lose their stickiness or leave sticky residues.
It might be a good idea to test with small sample pieces in an inconspicuous area before applying it to the entire back panel.
