I am planning to place a KALLAX shelving unit from IKEA in my bathroom to store towels, toiletries, and a few decorative items. Since bathrooms generally have much higher humidity levels—especially after showering or bathing—I am concerned whether the high moisture and possible condensation on the shelves could cause problems.
Specifically, I am interested to know if the KALLAX furniture, made from typical engineered wood materials (chipboard, MDF, or similar), can be damaged by prolonged exposure to increased humidity, for example through swelling, warping, or material deformation.
Does anyone have experience with this or know if such furniture can be safely used in a bathroom? If so, are there specific precautions to take, such as maintaining distance from the walls, increasing ventilation frequency, or applying protective treatments?
I look forward to well-informed answers and advice on using KALLAX units in high-humidity environments!
narDietmar3 Nov 2023 17:19I would like to add that regular ventilation not only protects surfaces but also improves the overall indoor climate and reduces the likelihood of mold on furniture.
Another tip is to line the shelves with thin boards or films that can repel moisture. This helps to reduce the direct impact of dripping water.
You should also probably limit the use in the bathroom to dry items to minimize the risk of water stains and permanent damage.
In conclusion: The KALLAX shelf can work in a bathroom under certain conditions if humidity is controlled and protective measures are taken.
